1994-1995 ODBII Port
To pull codes on 1994 and 1995 5.0 models, you have to plug into the EEC-IV port under the hood.
But what about that inop OBD-II port under the dash? What's at the other end of those wires? Does the port connect to anything? Anything at all?
I'm aware of that. I'm not trying to pull codes.
But this OBDII port is here, and it has some pins in it. There is a small bundle of wires coming out the back that continue running out-of-sight somewhere under the dash. My question is, where do those wires go?
There are only six pins in the connector: 2, 4, 5, 10, 13, and 16. I haven't probed any of them because I'm not sure what I'm getting into here. From what I've been reading, 4 is chassis ground and 16 is 12V+. That sounds like it could be useful.
The other pins seem to be for diagnostics only. 5 is "signal ground". 13 is for PCM programming. 2 and 10 are positive and negative bus lines, respectively. But I don't know if these can communicate with the PCM, or if they are even connected to it.
You honestly should forget that it's there.
You mean they just dead-end in a wire-loom somewhere? Oh well; I'm just asking out of curiosity anyway.
I'm really more interested in pins 4 & 16. If there's 12V power there, it would be nice to use it for accessories like a dashcam or GPS unit. But first, I'd like to know what circuit that would be. If those wires are sharing a circuit with the PCM, I'd rather just leave it alone. I don't want to burden the PCM circuit with an extra load that could pop the fuse.
TfcCDR
09-14-2015 12:08 PM
