Car loses power
Old 10-29-2015, 06:52 AM
87'5.0
87'5.0's Avatar
Default Car loses power
First a little info, I have a 1987 lx 5.0 that has been converted to mass air off an 89. This problem has only occurred twice but in first gear at about 4500 rpm the car just completely falls on it's face. But right after that happened I got on it again and it pulled harder than it ever has. Any ideas, thanks.
87'5.0 is offline
Old 10-29-2015, 07:29 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome to the forum.
I'd start by pulling codes, see if any are there that may point you in the right direction.
Then start looking at your fuel system, plugged filter, regulator, pump, lines, etc.
And just to clarify, this only happens in 1st gear ?
88 orangepeel notch is offline
Old 10-29-2015, 09:27 AM
87'5.0
87'5.0's Avatar
Thanks, fuel filter, then fuel pump was the next route I was going to take.
87'5.0 is offline
Old 10-29-2015, 09:30 AM
87'5.0
87'5.0's Avatar
Sorry, yes it only happened in first gear, it's only happened twice. Also like I said right after it happened I got on it again and it pulled harder than it ever has.
87'5.0 is offline
Old 10-30-2015, 06:44 AM
88 orangepeel notch
OK, don't just start throwing money at this without verifying. If this only happens in 1st gear, I'd rule out the pump. The filter is cheap and easy, and probably needs the be changed anyway.
And definitely pull codes before anything, it's free and easy, and could save you alot of headaches.
Old 10-30-2015, 08:37 AM
87'5.0
87'5.0's Avatar
I tried to pull the codes last night, but either there wasn't any or I wasn't doing it right. Do you know what color the self test input wire is, because there are two wires that look like it. One comes off the same harness and the other one comes off a harness right next to it. Maybe I wasn't using the right one. Or my check engine light might not be working.
87'5.0 is offline
Old 10-31-2015, 10:58 AM
87'5.0
87'5.0's Avatar
I think I have valves going out, I did a compression test and had 0 psi in two cylinders
87'5.0 is offline
Old 10-31-2015, 04:18 PM
87'5.0
87'5.0's Avatar
I can't believe my car ran as good as it did like this. It would still break the tires loose in second and chirp them in third.
87'5.0 is offline
Old 11-02-2015, 07:31 AM
88 orangepeel notch
Wow, good idea on the compression test.
Now, just imagine how much better she'll run with a good head gasket.
05 Mustang
Georgia Regional Chapter
02-17-2016 08:33 AM
Justpepper1999
10-29-2015 01:34 PM
gryon
10-29-2015 07:22 AM
IDGTCS
10-25-2015 09:50 AM
2004GTconvertable
10-24-2015 10:44 AM
Quick Reply: Car loses power
