Firing order
Old 10-30-2015, 04:21 PM
87'5.0
87'5.0's Avatar
Default Firing order
Is it possible to be one number off all the way around and still run decent. For instance when you look at the distributor where the number one plug should be mine is number 8. The order is correct I'm just off counter clockwise.
87'5.0 is offline
Old 11-01-2015, 08:10 PM
Boss_Hotrod
Boss_Hotrod's Avatar
It might run but it wont be decent. Timing would be off. The pickup in the dizzy has 1 blade that is thinner to signify to the pcm cylinder number 1. I will say that is the dizzy is off 1 tooth the engine will not run.
Boss_Hotrod is offline
Old 11-08-2015, 06:12 AM
64bit
64bit's Avatar
The distributor CAN be off by so much that you need to move the wires to get it to run. However, it will have serious effects on your fuel injector spray timing, which can either cause them to spray way too early, or way too late... depending on how bad you've stabbed the distributor.
64bit is offline
Diode Dynamics
20
07-02-2018 02:54 PM
rjwz28
GT350 S550 Tech
58
07-04-2016 06:14 PM
dtrufan
11-10-2015 01:51 PM
SteelerNation82
10-20-2015 09:58 PM
gagemcc
10-07-2015 08:59 PM
Quick Reply: Firing order
