Electrical help needed
My battery was draining dead when not using the car for a few days. I did the test with having the negative cable off and using a tester to hook from the cable to the negative side of the battery to see if there was a draw. It lit up so i knew it was drawing somewheres. I started unplugging fuses 1 by 1.When I unplugged the radio/instruments/power mirror fuse,the light went out on the tester so it was something to do with that. Is there any ideas on the fix or do I have to trace everything that the fuse powers to find the short?
