No fuel pressure I'm desperate
Hey guys so I've owned this 94 mustang for about a month and a half and it's been broke down for about a month I've tried everything that I can think of I've replaced the fuel filter and fuel pump and get nothing this problem started after I washed my car took it home and parked it then it wouldn't even crank after so I replaced the battery to block ground wire and it would crank except I wasn't getting any spark or any fuel. So I replaced the ignition control module, the distributor the coil and finally got spark back but only when the spout connector was disconnected so then I started on fuel so I replaced the fuel filter (which appeared to still be the stock one suuuuper dirty) and after I found the filter didn't work I replaced the fuel pump and I got dribbles but nothing more
So I checked to see if the fuel cut off was depressed and it was so I reset it and still got just a dribble I'm gonna replace the cut off depending how expensive it is and see where that gets me
I found that the inertia switch is not at fault as I have a 95 f250 with the same switch and tried it on my pickup and it works fine could the fuel regulator be bad? Sense before I had no fuel pressure I replaced the pump and now I it dribbles when I depress the schrader valve on the fuel rail?
Instead of throwing parts at it get a voltmeter and check for power and ground at the pump. There's multiple things that could cause no fuel pressure and you need to troubleshoot it before wasting a lot of money on parts that arent bad.
You could have a bad pcm, fuel relay, wiring, or inertia switch. just test stuff first.
[QUOTE=Boss_Hotrod;8522001]Instead of throwing parts at it get a voltmeter and check for power and ground at the pump. There's multiple things that could cause no fuel pressure and you need to troubleshoot it before wasting a lot of money on parts that arent bad.
I thought bout that but I figured sense most the parts that I've replaced were stock it wouldn't be a bad idea but anyway I've checked the relay under the hood replaced the CCRM fuel pump and the fuel filter the only other thin I could think of would have been the wiring or the Pcm any idea on how to test the PCM?
I just had a thought on the obd1 test port under the hood if you jump a connection it's supposed to check the fuel pump or relay or something but I know that the connection powers the fuel pump if I were to try that and the fuel pump didn't kick on would that work as a test point for the ECM?
