need more help after cleaning egr
94 5.0 codes were 334, 172, 176, 332, 210.
Was told to check for sticking, plugged EGR valve. Took off was not very dirty; moved the red thing and it seemed free.
Put back together ran great for about 30 mins then went back to what I call Hic cuping- tries to cut off but doesn't. Tach drops when this occurs, does it under full throttle or just crusing. May stop for abit then start again..
I'm lost what do I need to check now????
if car does not run rough at idle egr isn't screwing things up most likely......lean codes.....I'd search for a vac leak.....and you could of tested egr functionality with a simple hand held vac tester......apply vac to it and see if it makes car run rough or stall out.....if you don't have a tester...hook direct manifold vac to it for a brief second to test valve/system capability.
If the EGR was leaking the car should have more than just a lope to it. It would look like it was misfiring (shaking badly). If the EGR leak is bad enough the car will stall out since the car is not tuned (or designed to) for an EGR to be active at idle.
OK Update- Took off upper intake replaced 2 hoses that were broken off underneith. After test run seemed better , but still doing same thing. Found the yellow plastic hose going to egr was broken- repaired still same.
I guess next would be egr or the connector on it..
Thoughts
Thoughts
johnnie_2207@yahoo.com
12-19-2015 03:10 AM
Maine-iac
12-10-2015 02:24 PM
TravisJ33
12-01-2015 08:45 PM
BigDaddy0363
11-09-2015 05:39 PM
