1992 supercharged gt flooding
Hey guys my buddy picked up a 92 GT 5.0 vortech sc 42lb injectors Car will not run, its a stock block stock intake etc etc just with the vortech and injectors Its flooding TERRIBLY it will not start its pouring gasoline out of the cylinders pretty bad I have all the plugs out, has and adj regulator seems to be working properly hovering around 35 psi, it seriously seems when cranking that the injectors are all stuck wide open its dumping some serious fuel into the cylinders I'm kind of at a loss here? cause I have no idea what could be causing this, other than the stock computer not being able to handle the injector size any insight is appreciated
pull the inj rail and lay on a towel and see if a inj is stuck wide open....had one do such a while back so bad it was dumping it out the tail pipe, yup just one did that....once you find which one then you need to change the oil once it's repaired
depends on boost level but 42's are common on a stock boosted motor based on boost level..........you need to pull the rail up like I said and turn the key to on and see if they begin to start to spray to verify if all 8 are being held open in koeo mode, if so you'll see the problem.........so does it flood with key on engine off...meaning inj's pump fuel in to the motor? fuel pump should power up briefly for 2 sec in koeo and shut off after no pip is seen......if pump stays running in koeo after 2 sec you have another issue.
Changed distributor still no start, anyone? need help here bad? set tps voltage, changed all the sensors coolant, need to get to see if o2s are good idk, swapped computer with known good computer, swapped distributor with known good distributor
skinzy98
11-18-2015 10:23 AM
Silverblade
11-05-2015 09:50 PM
