Fuel pump or relay switch?
Old 02-04-2016, 05:43 PM
Mustang_Snoopy
Mustang_Snoopy's Avatar
Default Fuel pump or relay switch?
I have a 93 5.0 with 28k actual miles(owned it since 95), it has a Vortech T-rex fuel pump and of course when you turn the key it hums briefly then stops, well now after sitting up and the battery draining when I turn the key the humming does not stop and it wont start. Could it be the fuel pump or the fuel pump relay switch? If it is the relay switch, where is it located? Appreciate the help!
Mustang_Snoopy is offline
Old 02-05-2016, 08:05 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
is the battery currently fully charged?
mjr46 is offline
Old 02-05-2016, 09:50 PM
Mustang_Snoopy
Of course I fully charged up the battery. Turn the key and the fuel pump continuously hums, try to start and it turns over but it wont start. Has to be either the pump or the relay switch.
Old 02-05-2016, 11:09 PM
mjr46
mjr46's Avatar
so put a fuel pressure gauge on the rail and see if it has pressure
mjr46 is offline
Old 02-07-2016, 07:29 PM
64bit
64bit's Avatar
Does this car have a chip installed? Typically when the fuel pump runs continuously, its because of a loose or failed chip plugged into the PCM.
64bit is offline
facusessa
02-16-2016 02:32 PM
Dragonetti
02-06-2016 02:05 PM
blackliststang
02-01-2016 01:00 PM
Urambo Tauro
01-26-2016 06:56 AM
Quick Reply: Fuel pump or relay switch?
