Help With 94 Mustang
Old 02-07-2016, 12:56 AM
Lee1911
Lee1911's Avatar
Default Help With 94 Mustang
Hello all I need some serious help with my 1994 Mustang Convertible, I just say Mustang because I am no longer sure if it is a GT or if it was originally a 6 cylinder. This is the vin# 1FALP45T8RF228931. The car ran and drove but as I started getting into it I started seeing that it was missing plenty of stuff. Missing front seat belts, rear 1/4 panel trim speaker box on rear drivers side. The convertible top motor was missing and all 2 rear window motor are gone and the fronts are bad and no hand break. The seats are just nasty but those I was going to replace any way. I finally found the last of the interior parts I needed minus the seats and started pulling out the interior and when I was done I started looking over the motor to see why the gas pedal got stuck when I drove it home. It seems that its hanging up on the tubes that run under the throttle body. That's where I noticed that the motor doesn't look like others I saw in a 94 and 95. It looks like its a pre 94 motor. This is a mess I have picture to send if anyone can help Thanks all
Lee1911 is offline
Old 02-07-2016, 06:59 AM
64bit
64bit's Avatar
vin says its a 5.0
64bit is offline
Old 02-07-2016, 10:09 AM
Contidave
Contidave's Avatar
This is what the VIN decoder http://www.ford-trucks.com/forums/vi...LP45T8RF228931 online says:
General Information
MFR model code
P45
Body type:
Pass Doors:
Alternative name:
Alternative body:
Drivetrain:
Original Pricing
MSRP
$22,195.00
Invoice
$19,909.00
Destination Charge
$475.00
Engine & Powertrain
Type
8 Cylinder Engine
Displacement L/CI
5.0/302
Fuel Type
Gasoline Fuel
Horsepower
Fuel Economy
0.0 City / 0.0 Highway
Fuel Capacity
0.0
Net Torque
Tech Specs
Manufactured By United States Ford
It is a convert GT.
I sounds to me like a previous owner just really jack up repairs. Should be a good project. Once you go through everything you will have a nice car.
Here is a tip, when you go to your local U-Pick salvage yard take a bunch of shot with your phone on their 94s and 95s engine compartments and interiors. You will be surprised how your memory will mix up different engine looks and interiors from memory. The pics will help you return it to stock if that is your aim.
Contidave is offline
Old 02-07-2016, 11:46 AM
Lee1911
Lee1911's Avatar
Thanks I know it will be but the wife doesn't see it that way...The plastic bracket that holds the gas pedal cable and trans kick down cable is there a difference between the 94 and pre 94 ones.. I will post pictures tomorrow
Lee1911 is offline
Old 02-07-2016, 11:48 AM
Lee1911
Lee1911's Avatar
previous owner was a junkie
Lee1911 is offline
Old 02-07-2016, 02:30 PM
64bit
64bit's Avatar
94 and 95 do not have a kickdown cable.
64bit is offline
Old 02-07-2016, 04:28 PM
Lee1911
Lee1911's Avatar
Thanks for the help
Lee1911 is offline
hello2196
11-28-2015 10:42 PM
donvictorio
11-26-2015 02:58 PM
lincolnshibuya
11-23-2015 08:27 PM
KevinRoach
11-15-2015 08:17 AM
col2560
11-14-2015 09:49 AM
Quick Reply: Help With 94 Mustang
