Shifter Question
Old 02-26-2016, 12:28 PM
UltraBlue91'
UltraBlue91''s Avatar
Default Shifter Question
So I took off my shift ****, the boot, and the plating and silicone thing and was looking at my shifter. I took out the 4 bolts holding my shifter down and tried to pull it up and out. I then saw that the freakin thing was glued down with some type of strong adhesive around the whole bottom. I want to get a new short throw shifter and I was wondering if anyone had some ideas on how to get rid of the adhesive. The previous owner must have done that...don't know why besides to keep it extremely firm in place but the bolts should be enough to do that.
So anyone have some ideas? I was thinking about heating up the adhesive but I don't have a torch.
UltraBlue91' is offline
Old 02-26-2016, 01:18 PM
dawson1112
dawson1112's Avatar
Shove the shifter side to side nice and hard it will come off. They are all like that from factory. There isn't any thing in there you can hurt really.
dawson1112 is offline
Old 02-26-2016, 02:48 PM
UltraBlue91'
Interesting, didn't know that. There's already a short shifter in it, don't know the brand, so that means the previous owner used adhesive on it again. Well I'll give it a try then, thanks!
Old 02-26-2016, 05:30 PM
64bit
64bit's Avatar
What a good laugh.
Thank you.
Put the trans in neutral and slam the shifter side to side. It'll pop off.
64bit is offline
Old 02-26-2016, 05:44 PM
UltraBlue91'
I'm glad you enjoyed yourself. I wasn't about to force anything before finding answers, hence the reason for my post. I've only been in the Fox game for a few months so excuse my lack of knowledge. Do people usually reapply adhesive? Should I?
Old 02-26-2016, 09:19 PM
64bit
64bit's Avatar
yes. it's not used as an adhesive... but rather, a sealer. There are reusable rubber gaskets that you could use, but I just silicone them.
There is fluid under them afterall.
64bit is offline
Old 02-26-2016, 11:56 PM
Urambo Tauro
Urambo Tauro's Avatar
The instructions for my Tri-Ax call for silicone gasket maker. I used Ultra Blue RTV.
Urambo Tauro is offline
Old 02-27-2016, 12:21 AM
UltraBlue91'
Thanks guys, I'll make sure to use the sealer when installing the new shifter.
Old 02-29-2016, 07:48 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
good, because that's how they are sealed....simple rtv will be fine
mjr46 is offline
Old 03-03-2016, 12:01 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Stuff I use on mine is glue (honda ultraflange). I could take the bolts out and drive the car and not break it free. I usually have to get under car and use a screwdriver/prybar and hammer and knock the crap out of it to break it free.
Boss_Hotrod is offline
Offendant
02-25-2016 07:10 AM
Rickf1985
02-23-2016 01:59 PM
gtgosa
02-23-2016 04:15 AM
Drastang
02-20-2016 10:54 AM
BlackRat
02-12-2016 11:40 AM
Quick Reply: Shifter Question
