Running lights and headlights do not work.
Old 03-03-2016, 01:39 PM
19stang88
19stang88's Avatar
Default Running lights and headlights do not work.
Hi eveybody.
I have searched online on how to fix my headlights and no luck. I am hoping go get help here.
I have a 1988 GT. In the past my headlights would have issues and randomly flicker. I replaced the headlight bulb with a bulb with less output watts and that solved the issue. Over time, my lights started to flicker again with just the low beams and eventually shut off. High did not work. I would have to hold the multi function switch on the flash to pass position to maintain the lights while driving at night. Eventually my lights would not even turn on, not even with the multi function switch. So I thought I burnt the headlight and multi function switch and replaced them both. Still my lights will not turn on to include my running lights. Also my left blinker doesn't work but my right one does. I have done the obvious like check the bulbs and fuses, everything is good. I would like to drive my car at night again. Any help is appreciated.
Thank you
19stang88 is offline
Old 03-03-2016, 03:33 PM
dawson1112
dawson1112's Avatar
My guess is that the main plug in the dash is burnt. Its common problem on foxbodys
dawson1112 is offline
Old 03-03-2016, 07:59 PM
19stang88
19stang88's Avatar
Is this the plug you're talking about?
Old 03-03-2016, 08:05 PM
dawson1112
dawson1112's Avatar
That's the one
Old 03-03-2016, 11:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if the car has fog lights, sounds like they may be the root cause to all the probs, common they burnt up connectors an fuse box inside the car
mjr46 is offline
Old 03-03-2016, 11:07 PM
19stang88
19stang88's Avatar
That's the one
I'll order it. I checked it out and it's not burnt. I have acess to a multimeter. Where do I test?
Old 03-05-2016, 05:20 PM
19stang88
19stang88's Avatar
I just tested a few areas. Im getting 12vdc at the multifunction switch from both red and black wires for low beam and green black for flash to pass. When i connect the multimeter at the headlight bulb connection i am drawing nothing, keep in mind the headlight switch is completely on. Is there something that i am missing. I am suspecting a open somewhere..
Old 03-05-2016, 05:21 PM
19stang88
19stang88's Avatar
I forgot to add, the front parking lights do not turn and and only my passenger side blinker works.
Old 01-12-2020, 10:20 AM
19stang88
19stang88's Avatar
Hope's this helps if anybody comes across it. This ended up being a grounding issues. Also, i found a connector that wasn't fully seated, I can't remember which one, i just remember it was in the engine bay. basically, start out by checking out all your connections and grounds.
Marky82
10-09-2016 06:19 PM
guitarman376
01-06-2016 12:54 PM
Jly154
01-04-2016 03:39 PM
99karma
12-26-2015 08:13 PM
GeneralMustang
12-20-2015 07:11 PM
Quick Reply: Running lights and headlights do not work.
