installing a procharger on a 94 5.0
I'm buying a complete procharger setup. My only questions are if anyone has suggestions on what size injectors I should upgrade too and what fuel pump I should run. The motor otherwise is stock thanks for any input
Mine has 42's and a 255. I turn it 6k, 12 pounds of boost. Car was tuned at 9 pounds I think. It had a 3.12 pulley then. Today it has a 2.85 and I added meth to compensate not getting a re-tune. It was at 460 hp with the 3.12.
To add onto what OrangeNotch posted, the 94's and 95's can be troublesome to tune. I'm not saying professionals couldn't do it. The computers are different from the foxes and specific to just those two years.
Sounds to me like your losing all electrical power for an instant. Check wiring around neutral safety switch, ignition switch, battery, etc. Sounds like a loose wire, bad connection or a bad ground somewhere.
Good luck
Good luck
matt_90lx
03-09-2016 06:55 AM
matt_90lx
02-24-2016 06:39 AM
