A/C knob spinning freely
Old 03-23-2016, 07:52 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
there should be no springy at all.........if it is binding or not closing to one position the problem is in the heater box....often warpage causing the blend door to bind....seen it plenty in these old foxes......you are making a mountain out of a mole hill......the control panel is just a know attached to a toothed slide, that connect to the cable......if control head is fine and cable are fine...it's obvious where the issue is
mjr46 is offline
Old 03-24-2016, 07:24 AM
ponyboy302
ponyboy302's Avatar
Ok so I have talked to a couple mechanics. Around the blend door is some type of weatherstripping material like a cushion. This is what seems to cause the springiness and why there is no positive stops. It will compress with pressure but will go back to its original form when pressure is released.
ponyboy302 is offline
1988MUSKRAT
01-24-2018 06:16 PM
robriley3474@gmail.com
03-17-2016 09:51 AM
Mustang Videos
03-14-2016 03:40 PM
Offendant
03-11-2016 10:03 AM
2001svtcobra
02-20-2016 11:59 AM
Quick Reply: A/C knob spinning freely
