Freshly Rebuild T-5, I'm breaking it in, literally
Hey guys. Just got my 65 stang back on the road with a V8 swap and a WC T-5 from a 1991 Foxbody. The trans had bad synchros so I had it rebuilt with new synchros, bearings, races, and seals. Anyways, I was beating on the car a little today, spun through 1st, and when I went to grab second gear I must have released the clutch a little too early. As it went down into second there was a bad clunk/grind and it shook the car. Almost felt like I broke a U-Joint. Felt really bad that it happened. But I drove the car home and it went into second gear fine each time. Even got on it a little and it went in 2nd gear fine. Just sharing a little greif with you guys, just thinking that I might have taken a chunk out of a gear or something. Anyone have any idea on what the carnage could be, if any?
I'd definitely drain the trans and check the fluid with a magnet. You could search around a little inside your trans with a magnet http://www.lowes.com/pd_587682-73126...4-d719400f0f44
no t-5 I have ever rebuilt has ever not needed a 2nd and third gear as the snychronizer teeth built onto the hub of the gears are always mushroomed flat from years of abuse, when they should be pointy like a roof top........ when shifting quick this issue often manifests itself like a quick grind or catch.
damage done? I think what I stated most likely could have been overlooked by your rebuilder, which is often the case if they don't specifically specialize in one area/ make of trannies.
94gtconvertible
10-04-2005 12:02 AM
BigJoe1125
09-09-2005 02:27 AM
