Braze, Soder, Weld Convertible Top Hinge?
Hey everyone, I am in the process of restoring an '89 foxbody mustang. On one side, the hinge of the convertible top is broken. There is a piece that holds the front of the top up, so that when the top is being put back on, it falls in the right position. It probably supports about 30 pounds of weight, but only for a few seconds at a time. That piece is broken, so the hinge is now falling in the wrong position and needs to be supported by hand when it is being put down. I have heard you cannot simply weld this metal. I have very good ability and resources for welding both steel and aluminum. The problem is, I am told this is neither. What do you all recommend for fixing this. It probably supports too much weight to JB weld or Epoxy it, and I'd prefer a better fix than that anyway.
the problem with any of those fixes is that you are taking something that was 1 piece before and making it 1 piece again with a failure point where the weld/braze is. it will fail in that exact spot again. you will be better off replacing the part, or assembly
The problem is, to replace that assembly I would have to replace the entirety of the convertible top bows.
I have very good ability and resources for welding both steel and aluminium. The problem is, I am told this is neither.
Is it magnetic? Btw, Jwog has never been wrong to my knowledge, I would try to weld it if it is magnetic. The actual weld is usually stronger than the original metal, but the area around it will probably we weaker and break next to the weld. Brazing will not hold it. Is there a way to add a gusset or strengthen it with additional metal?
rocket22
07-21-2018 10:45 AM
