Weird Power Window problem
So I've been working on an 89 GT Restoration for like the past 6 years and I have had the interior torn apart and am just now getting around to putting it back together. I had to replace the passenger window motor and I just put it in and when I went use it, it went right down. No problem. Except that when I tried to put it back up, nothing. Went over to the drivers side switches and tried to put it up. Nothing. Tried to put the driver side window up or down. Nothing. When I push down on the passenger window switch from either side, I can hear it click. The driver side window did not work while I had the passenger side motor and switch out, but I figured it would when I put it back together to complete the circuit? Could it be something else that I don't have connected? The center console is still removed so Mirrors and Cig lighter aren't connected and seats are aftermarket so the lumbar isn't connected. Any ideas? I'm totally stumped. Thanks.
Sorry I can't be much help for a exact cause, but a multimeter meter will let you know where your power is being held up. Might have to take the time to probe from the motor back to back to find the culprit.
Good luck
Good luck
