93 Cobra clutch issue
Old 06-09-2016, 04:42 PM
jperz89lx
jperz89lx's Avatar
Default 93 Cobra clutch issue
I've got a 93 Cobra with stock clutch/tranny/shifter.
When the clutch is engaged (my foot is completely off the clutch, correct me if I'm wrong) there is a loud clicking noise and a strong vibration in the clutch pedal, doesn't really matter what gear I am in, but you can hear it best when it's just idling in neutral.
If i push the clutch in, clicking goes away, and the vibration goes away.
At first I would only hear it when the car was warmed up, but it's gotten progressively worse, the more I drive it, and now it's pretty much constant (unless I'm pushing the clutch), so I'm getting worried.
Has anyone else experienced this? If so, do I just need to do some adjusting, or is my clutch going? I should mention, otherwise, the car shifts great, although sometimes I have issues getting it into reverse, but every fox body I've had has had that issue.
jperz89lx is offline
Old 06-09-2016, 04:55 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Not sure why the pedal would vibrate. If the noise is present while your foot is off the clutch I would suspect something in the tranny, such as input bearing or counter shaft bearings since those turn in every gear, even neutral, with the clutch engaged (foot off pedal).
Boss_Hotrod is offline
Old 06-15-2016, 08:33 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
most likely it's the throw out bearing, pull the tranny and bell housing
mjr46 is offline
MustangVixenGT
04-06-2016 08:55 AM
Mach2
04-01-2016 03:37 AM
xNightFirex
03-17-2016 05:49 AM
plane225
03-16-2016 10:14 PM
TrentSzopinski
03-14-2016 06:52 PM
Quick Reply: 93 Cobra clutch issue
