Roller lifters with stock rockers?
Old 06-25-2016, 08:44 AM
jdthedj10
jdthedj10's Avatar
Default Roller lifters with stock rockers?
Can I use my stock rockers arms with roller lifters? Also, can I use my stock push rods or should I upgrade?
jdthedj10 is offline
Old 06-25-2016, 01:12 PM
dawson1112
dawson1112's Avatar
Your stock 5.0 is allready using stock rockers with stock rollers lifters.
dawson1112 is offline
Old 06-25-2016, 10:37 PM
jdthedj10
jdthedj10's Avatar
Thank you for the information. I am trying to put parts together before the tear down.
Old 06-27-2016, 08:24 AM
88 orangepeel notch
88 orangepeel notch's Avatar
And the use of your stock push rods will be determined what cam, pistons, rockers, heads you go with. If your switching any of those at, you'll need to check/verify push rod length during assembly.
When you get a list made up, don't be afraid to share it here,. We'll give friendly advice on your choices and try to save you money in the long run. If needed........
88 orangepeel notch is offline
Old 06-27-2016, 02:07 PM
jdthedj10
jdthedj10's Avatar
Thank you for your help. Here are the cam specs.
Old 06-28-2016, 06:51 AM
88 orangepeel notch
What are your plans for the car ? Daily driver, street - strip fun car, dedicated track car ?
The cam will determine where your power will come in, but more importantly ALL parts must be put together so they work together.
What other parts are planned for the motor ?
Old 06-29-2016, 08:12 PM
jdthedj10
jdthedj10's Avatar
I have added a BBK CAI, BBK header back H pipe, Moroso ignition coil, ford racing 8mm wires, new autolite 25s and am currently looking for a gt40 upper and lower intake and 73mm TB. I want a very fun daily driver, maybe some street strip fun every now and then.
Old 06-30-2016, 07:22 AM
88 orangepeel notch
The first thing I'd recommend is a gear swap,........3:55-3:73. That alone will give you the biggest bang for your buck by far.
And when it comes to cam specs, I'm not the guy to ask lol. Hopefully some of the other (smarter) guys will chime in and let you know if that's a good cam for your list of mods.
Old 07-01-2016, 11:13 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you would be wise not to use stock stamp steel rockers with that cam...infact you should get a set of heads that allow the use of stud mount rockers.....as pedestal mount rockers are non adjustable
mjr46 is offline
Mustang6713
11-30-2022 09:15 PM
FordTrax
06-23-2016 07:35 PM
Elladine
06-16-2016 03:47 PM
Luis_04Mustang
06-08-2016 10:49 AM
snowman_45
06-03-2016 04:54 PM
Quick Reply: Roller lifters with stock rockers?
