Will not turn over
Will not turn over
I have an 89 Mustang GT 5.0 L. When I turn the key to start the solenoid clicks one time and then will not click anymore until you turn the key off wait a few seconds and try again. The solenoid can be Jumped across and the car will turn over but not start.
The car was in high enough water to get in floorboards. A little higher on passenger side than driver but definitely not up to any wiring under dash.
Failed to mention car ran fine until water issue. It was not running in water only sitting.
I replaced solenoid.
Any other suggestions.
Check your fuel pressure and confirm spark. Can you hear the fuel pump run for a second or two when you turn the key to on? If the water got the carpet wet it could have easily gotten to the fuel pump relay under the driver seat.
06-23-2016 04:59 PM
06-16-2016 10:41 AM
06-15-2016 01:42 PM
