Next Mod?
Next Mod?
With the mods in my sig, I hope to be in the high 13's, and next I am looking at getting Trickflow Intake and B-303 Cam, What do ya think.....I know H/C/I all at once but I dont have the 1300 for the Afr 165's but I do have 550. Also I am looking to get a 75-100 shot of zex to get me in the 12's when I need it.
Next Mod?
Mabye get the Zex first, or buy an intake what ever you want. Alsoyou should get a better cam thanthe B-303. If I could go back I would have gotton a bigger cam not that the b-303 is a bad one.And you should buy 185s not 165s.What do you think you run now anyway low 14s ? With those mods I thought stangs ran in the high 13s at least? Traction problems ?
Next Mod?
i say go to trick flow for the cam. then you can get the twisted wedge heads and since it is all designed to work together you will not need to port match and the cam will work perfectly!!
Next Mod?
i had a 94 gt auto. converted it over to 5spd had under drive pulleys k&n filter and the stock 327 gears that the autos come with and it ran 13.80's on street tires. 17x9 cobra r's all they way around. you should be able to get there easy. and just remeber not to worry about parts. if you break them they can always be replaced. and never lift it is funner that way.
Next Mod?
wydoporn all i have to say is wow. </P>
you need 2, one for each head. btw, it would be worth to get the i/c before. the intake willgive you 30 hp. and cams will give you more powertoo.</P>
