bucking and jumping around low rpm
Old 07-13-2016, 12:37 PM
sc90fox
sc90fox's Avatar
cause the timing or the coil.
sc90fox is offline
Old 07-13-2016, 01:39 PM
dawson1112
dawson1112's Avatar
If its out of time it wont run properly.
dawson1112 is offline
Old 07-13-2016, 02:17 PM
sc90fox
sc90fox's Avatar
YEA BUT IF I CANT GET IT TO IDLE IS IT OKAY THAT I HAVE SOME ONE KEEP IT RUNNING AND SET IT THAT WAY?
sc90fox is offline
Old 07-13-2016, 09:21 PM
sc90fox
sc90fox's Avatar
Well set the timing to ten and it idle but at like 1900 and adjusted the screw and it's goes from like 1500 to 600 with a flick of the wrist. Well I let it warm up and tried to go for a drive and it started to run bad and just died. Sprayed all vacuum lines down with carb cleaner and no increase in idle so vac is good. Spark is decent. Fuel pressure is average. What's next
sc90fox is offline
Old 07-14-2016, 06:50 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Have you pulled codes yet ? With it dying all the time, you'd think the computer would have stored a couple that might help point to the problem.
As for the idle, a "Base Idle Reset" might be in order.
And that's only if your 100% sure there's no vacuum leak.
88 orangepeel notch is offline
Old 07-14-2016, 08:22 AM
sc90fox
sc90fox's Avatar
THERE SHOULD BE NO VAC LEAK ANYWHERE. NOT TO SURE HOW TO PULL CODES OR THE BASE IDLE RESTET. COULD YOU EXPLAIN HOW THAT WOULD BE GREAT. THANK YOU
sc90fox is offline
Old 07-15-2016, 07:12 AM
88 orangepeel notch
Sure, just search this forum or Google it. You'll find step by step instructions on how to do both.
Report back with what you find.
EDIT: I was bored so here you go
Base idle reset.......... http://sbftech.com/index.php/topic,1031.0.html
Pulling codes...........http://dfwmustangs.net/forums/showthread.php?t=7908
Old 07-15-2016, 12:33 PM
sc90fox
sc90fox's Avatar
WELL NO LUCK ENGINE LIGHT IS ON WHEN I START THE CAR BUT NO ENGINE LIGHT WHEN CAR IS NOT ON.
sc90fox is offline
Old 07-16-2016, 05:20 PM
sc90fox
sc90fox's Avatar
Well found some codes
15 23 85 Koeo
Cm 13 16 36 69 63 17 59
sc90fox is offline
Old 07-19-2016, 06:49 AM
88 orangepeel notch
http://www.fiveohinfo.com/fox/eec.php
I'd clear the codes, do a base idle reset to see if that helps the TPS codes, then drive it normally for an hour. Then pull codes again to see what's going on.
That Error code 15 has me worried though. That's the internal chip in the computer saying something is wrong with the computer itself. Hopefully that one doesn't come back.
Quick Reply: bucking and jumping around low rpm
