What Fresh Hell Is This?
So where to begin...
We decided to replace the following on my son's 87 GT. It was running fine but we wanted to add on shiny new parts. Here is what we did:
* New upper and lower intake (and gaskets) - Typhoon
* New Fuel Injector Wiring Harness
* New 19lb injectors - Accel
* New Spark Plug wires
* New PCV
* New 160 degree thermostat
* New Idle Air Control Motor
So now I have a rough idle (stalls easy) but I have white smoke coming out of the passenger side exhaust (none from the drivers side).
Before I start tearing everything apart again does anyone have any ideas?
* New PCV
First thing verify your timing, firing order and vacuum lines. Is your coolant level the same? White smoke usually indicates coolant getting in to the combustion chambers.
This is alittle off topic, but swap that 160' thermostat to a 180' or the stock 195'. The computer will think it's always in cold start mode and run in "closed loop" or choke mode. Ruining your gas mileage and cause premature engine wear.
2001svtcobra
02-20-2016 11:59 AM
