AC blows cold but not strong
Old 07-27-2016, 01:53 PM
jdthedj10
jdthedj10's Avatar
Default AC blows cold but not strong
My air conditioner just recharged blows nice and cold however does not blow strong I did some research and found out of there is not a cabin air filter in the 94 model GT. My question is how in the world would I get in there to clean the squirrel cage fan? I am assuming it has some dust buildup on it limiting them out of there that it can move. It gets Mighty hot in here.
jdthedj10 is offline
Old 07-27-2016, 02:59 PM
Derf00
Gentleman's Relish
Derf00's Avatar
When you take it out, make sure the blower wheel itself is in not cracked or spinning freely on the motor shaft. That's usually what happens. The plastic wheel gets rounded out then no longer spins with the motor so you have decreased air flow.
Also, the blow motor speed resistor may not have all speeds available (burnt out) so even though you put it to 2, 3, or 4 you might only be getting speed 1 and/or 2.
Derf00 is offline
Old 07-27-2016, 05:41 PM
jdthedj10
jdthedj10's Avatar
Originally Posted by Derf00
How To Install Replace Squeaking Groaning AC Heater Fan Ford Mustang 94-04 1AAuto.com - YouTube
Thank you very much!! My weekend project.
Old 07-29-2016, 03:20 PM
WJBertrand
WJBertrand's Avatar
Does the fan operate in all of the speed settings? If not you could have a partially blown blower resistor.
WJBertrand is offline
Old 07-30-2016, 01:15 PM
jdthedj10
jdthedj10's Avatar
Yes, I checked the 1 at a time and each one blows stronger than the last. I took the fan out and scrubbed it. It was Covered in soot. I did notice though that the far right passenger vent isn't connected to anything and I can't see a place where it is supposedifficult to connect. Any clues on that?
Old 07-30-2016, 03:11 PM
jdthedj10
jdthedj10's Avatar
LOL, boy am I dense. The I have discovered that there is an entire section of duct missing. Just bought it. That should make a difference!!
injentechnology
08-28-2016 06:16 PM
dlee
07-14-2016 03:31 PM
MustangKart
07-12-2016 07:42 PM
dlee
07-06-2016 08:50 PM
MNMustang
07-03-2016 01:04 PM
Quick Reply: AC blows cold but not strong
