Low Fuel Pressure
Old 09-24-2016, 09:09 PM
Rid21
Rid21's Avatar
Default Low Fuel Pressure
My fuel pump went bad on my 94 5.0. I have replaced the fuel pump with a BBK electric pump fuel filter and I have replaced the fuel pressure regulator but I can't get the car to crank. And my fuel pressure is only showing that I have 20lbs of pressure. The car will crank when I sprayed gas down the throttle body so I know the problem is in the fuel delivery system. Any idea please help! Thanks
Rid21 is offline
Old 09-25-2016, 09:24 AM
switch625
switch625's Avatar
Your post is confusing. You say the car won't crank, but it will crank when you spray gas down the throttle body? So your car will crank it's just not starting?
switch625 is offline
Old 09-25-2016, 09:46 AM
Urambo Tauro
Urambo Tauro's Avatar
Welcome!
Please be clear how you word things. "Spraying gas down the throttle body" has no effect on whether a car will crank over or not. "Cranking" has to do with the starter's ability to turn the engine, period.
I think you're trying to say that the car cranks but does not fire unless you manually add starting fluid (or in your case, gas). 20PSI is too low, so let's focus on that. Did you prime the system and bleed the air out? Is there any chance you pinched or damaged a fuel line during reassembly?
Urambo Tauro is offline
Old 09-25-2016, 01:04 PM
Rid21
Rid21's Avatar
Sorry I'm new to this. Car will not start unless gas put directly into the throttle body. I have checked the fuel pressure at the rail and it's only gettin 20lbs. The actual fuel lines were never touched.
Rid21 is offline
Old 09-25-2016, 01:05 PM
Rid21
Rid21's Avatar
How would I know if there is air in the line? And how would I go about bleeding it out
Rid21 is offline
Old 09-25-2016, 08:33 PM
Urambo Tauro
Priming the lines is as simple as turning the key to "ON" a few times (without starting it). If you push the little plunger in the schrader valve, fuel should squirt out.
How did you replace the fuel pump without touching the lines? Did you drop the tank or cut a hole in the trunk for access?
Old 09-25-2016, 09:10 PM
Rid21
Rid21's Avatar
Dropped the tank. Only places where the lines were touched was reconnecting them to the fuel pump hanger after the pump was put in. Gas does come out at the valve. That's where I tested the pressure on it after the pump and regulator was replaced.
Rid21 is offline
Old 09-29-2016, 10:54 PM
Rid21
Rid21's Avatar
I think I've narrowed it down to the fact that the fuel pump is only getting 7.9 volts. Would that be the problem with the pump not supplying enough pressure? And is the low voltage a sign that there is something wrong with the CCRM?
Rid21 is offline
Old 09-30-2016, 06:41 AM
88 orangepeel notch
88 orangepeel notch's Avatar
There's your problem, you definitely need 12v to run the pump. Give the wiring a good once over for clean connections and grounds. Testing voltage along the way...
88 orangepeel notch is offline
Old 09-30-2016, 09:35 PM
Rid21
Rid21's Avatar
Gonna check the CCRM and see what the voltage is there. As far as I know there's no other connection between there and the interia switch or am I wrong?
Rid21 is offline
Floorguy
3.7L V6 Technical Discussions
21
10-13-2016 08:41 PM
ryan3055
07-25-2016 04:57 PM
Umbertone
07-23-2016 03:11 PM
Umbertone
07-10-2016 10:07 AM
Umbertone
07-05-2016 12:13 PM
Quick Reply: Low Fuel Pressure
