TPS wire (black wire)
So i had mentioned in an earlier post about intermittent surging on an 89 Mustang LX 5.0 that i had just picked up. I took a look at the TPS sensor tonight and noticed the black wire was all jacked up. Looks like the P/O broke it and tried to fix it, but did not do it the proper way. Being as the TPS voltage needs to be precisely set at .96-.98v, could this wire being held together by nearly a thread throw it off this much as to cause the intermittent surge? i have attached pics.
Thanks All!
Thanks All!
I'm no expert in this, but I'd assume it's still working if the car is still drivable. Without a TPS signal, the car may idle, but the ECM would have a fit when you tried to drive it.
Definitely get it fixed, but I don't think it's the cause of your surge.
I don't know what you've all done to search for this, but there are a ton of threads on steps to take. My car had a slight surge a while back and I did all the things that are recommended to find the problem and nothing really helped. I also run an Anderson PMS and i found that if I pulled 2' timing at idle it smoothed everything out perfectly. That probably doesn't help you much, but it's what cured mine.
Good luck
Good luck
Good luck
Good luck
Yep, that may help. But it seems 90% of a surge problem can be linked to even the smallest vacuum leak. Make sure your 100% sure there's no leak. Then I'd clean the IAC, MAF sensor, and do a base idle reset.
Good luck
Good luck
Thanks!
