Firing order for 82 GT?
Old 10-30-2016, 05:22 PM
SKOT
SKOT's Avatar
Default Firing order for 82 GT?
OK so I replaced the dist cap and wires...didn't pay attention to the old wires I figured I have a ford powertrain manual so.....WELL I wired it up 1,3,7,2,6,5,4,8 BC that's what ive been told the order was....engine barely runs and backfires...according to the ford manual the aforementioned order is for 351...the 302 is 1,5,4,2,6,3,7,8....but that's supposed to be for then non HO engines...I ran out of time and didn't get to change to the other order.... any info?
again thanks
SKOT is offline
Old 10-30-2016, 09:44 PM
mongolchuck
mongolchuck's Avatar
If that is the original motor it should be the ho. Make sure you didn't turn your distributer and remember ford numbers cylinders different than gm. 1234 on the right (pass) side front to back. 5678 left (driver) side front to back. Dist turns counter clockwise when looking from above.
Here's a link with a good illustration.
http://www.gtsparkplugs.com/firing-order-ford-302-351.html
mongolchuck is offline
