No start after timing chain and intake gaskets?
Old 10-31-2016, 04:34 PM
SKOT
SKOT's Avatar
Default No start after timing chain and intake gaskets?
82 HO..changed timing set, removed dizzy for cleaning (restoration) and replaced back at removal marks..Replaced intake gaskets and now have no start. Tries to start but stumbles and dies.. Checked TDC at the crank with no1 piston position and rotor position all good...Checked fire at all 8 plugs all good.....Same carb that was running correctly B4..also replaced dizzy stator but im getting fire so assume that is also good.....Im out of ideas LOL
Thanks
SKOT is offline
Old 10-31-2016, 10:39 PM
88 orangepeel notch
88 orangepeel notch's Avatar
When you checked timing marks, were you sure #1 cyl. was at TDC on compression stroke ?
Sounds like dizzy is off 180'.
88 orangepeel notch is offline
Old 11-01-2016, 06:42 AM
SKOT
SKOT's Avatar
Default Reply
Yeah both valves closed used the Ole thumb on the plug hole ...
SKOT is offline
Old 11-01-2016, 09:42 AM
mongolchuck
mongolchuck's Avatar
It is very easy to get that dist off one tooth. I would restab it to be sure. There is an excellent write up on it in the stickies I believe.
mongolchuck is offline
Old 11-03-2016, 03:01 PM
SKOT
SKOT's Avatar
Default OK
I checked compression and all 8 were between 120-130 considering this is a 100k mile car I guess that's no too bad....? Getting fuel fouled plugs and going to use to non foulders to see if I can get this to run...
SKOT is offline
Old 11-04-2016, 08:32 AM
88 orangepeel notch
"Non Foulders" are not going to help, they only fit the 7.3 diesels and are very expensive............lol
Seriously though, keep is updated
Old 11-10-2016, 03:57 PM
yurizx6r
yurizx6r's Avatar
You didn't try to advance or retard the timing on the chain did you?
yurizx6r is offline
Old 11-10-2016, 07:41 PM
SKOT
SKOT's Avatar
nope replaced it exactly as it came out
SKOT is offline
Old 11-10-2016, 08:03 PM
yurizx6r
yurizx6r's Avatar
Ok. I tried advancing my timing on my chain by 3 degrees once (YES I DID IT RIGHT, you cant screw it up), turned it by hand to make sure it was good, and then it wouldn't start. I had to play with the distributor to get it to finally start annnnnnnd bent all of my push rods on the intake side. Don't know why it happened, but it did. Put the chain back to factory spec and it started right up even with the bent rods.
yurizx6r is offline
Old 11-11-2016, 07:56 AM
88 orangepeel notch
OUCH ^^^.......you got ***** for sharing that one lol. Hats off to you.
OP, you probably checked this already, but I have to ask. Your using the 5.0 HO firing order and the wires are routed correctly ?
