F303 cam ?
F303 cam ?
So I'm thinking of installing the F303 cam installed into my Mustang. When I had the GT 40 heads ported I had Tric Flow valve springs kit #2500100 from late model restoration supply installed. My question is will this valve spring package work with the F303 cam or is the cam too much?
If you stuck on the F cam those springs should be fine. But as long as your going in there I'm sure you know there's better cam choices out there then the letter cams. Even though I'm running one lol.
I'd do alittle research and dig around to see your choices, but a custom cam from a reputable cam maker is just about the best bang for the buck you can get. And being a critical part to power, it may be worth the investment. I've never heard anyone complain about going that route.
Good luck
Good luck
