E303 cam needs
E303 cam needs
So Im rebuilding my 5.0 and I bought a E cam for it it's bored .030 and Ive heard u can't use stock valve springs and rockers with the set up ... I had bought new valve springs but I guess they don't fit the heads correctly... I just need to know wat I need and an explination behind it because if I can use the stock head assembly that would be great... thanks
nope, can't use stock springs, spring rate is inadequate and valves will float and a set pedestal roller rockers to clear the new springs ..... check this place out https://www.alexsparts.com/categorie...SPRING-KITS/of
