Need Help 1995 Mustang GT
I have a 95 mustang gt. when I first start it up in the mornings it runs fine. once it warms up to 160 degrees it starts misfiring and having a small jerk at steady speed anybody know what this could be.
i have replaced the fuel filter, fuel pump, maf, o2 sensors, tps, coolant temp sensor. when i had this problem before but it was worse than what it is now. after i changed the maf and o2 sensors it stopped doing it for awhile now its back but not near is bad as last time.
So if I understand you correctly you are able to get the car to go into diagnostic mode using the jumper method it just isnt storing codes?
My first thought is you have a bad PIP inside the distributor. Or your coil is failing once it gets hot.
