aftermarket rear control arms , panhard bar , springs(maybe with matched shocks struts), solid rack bushings and better end links,solid steering shaft , better front lower control arm bushings, sub frame connectors, strut tower brace , k member braces are cool too, and some caster camber plates to take advantage and correct your align ment once it is lowered. not in any order or nor do u have to get them all. and dont get the heaviest springs you can find , cuz then your shocks may not be able to dampen them correctly.
