Overall Output numbers
I believe you have an easy 350hp at the crank. But two important factors you didn't mention: Compression ratio, injectors size. if you have 19LBs better get a set of 24lb. A 10:1 compression is the best with pump gas. you could reach 390hp or more with this setup.
Ive got 24# injuectors now but they're sh*tty, Im gonna replace em and a new MAF meter as well. I don't want to change the compression just because I don't want to cut the engine life short... I've got whatever compression is stock on the 88 GT.
breaking
10-02-2015 01:27 PM
09-23-2015 01:28 PM
