tachometer
tachometer
Ya I wanted to know if anyone knew aboutthis one tach that I had my eye on. It says its for engines with factory ignitions. Which mine has but why would that matter at all ?</P>
</P>
<IMG src=uploads/T5superduty/263A6_2895.JPG border="0"></P>
tachometer
The tach can "read" how often the crankshaft rotates by "sensing" the ignition pulse (from the coil to the distributor.) (This is the same raeson it matters whether you have a 4-6-8 cylinder. In 8 for example; for each crankshaft rotation, the coil sends four pulses to the distributor.) On an aftermarket ignition, the tach might not be able to "sense" the pulse. I'm not sure why exactly that is. The service guy at AutoMeter is great, email him.
tachometer
Wait the tachometer reads how many revolutions per minute the crankshaft rotates? I always thought it was the camshaft. I might have got them confused because the cam is the brain and its telling the crank to do that. Wow I feel dumb now if that is true.</P>
