i need carb help, BAD!!!
i have a 1985 ford mustang gt. its a monster, nothing is stock. i cant get the carburetor tuned right and im completely out of ideas. here are the specs:
302 bored .030 over
10:1 compression
world windsor sr heads (64cc chambers, 2.02/1.60 valves), heavily ported.
ford racing x303 hydraulic roller cam, 1.7 roller rockers (.578 lift exhaust and intake, 224 duration @ .050)
edelbrock victor jr intake (single plane, high rise)
full msd ignition, digital 6-plus box.
18 degrees initial timing.
holley blue fuel pump, 3/8 aluminum fuel line, aeroquip a/n fittings.
110 octane racing fuel.
T-5 manual trans, 3.73 posi rear end, aluminum driveshaft.
and finally the problem, a proform 650 carburetor.
the primary jets are #72, secondary - #80 with jet extensions, power valve - #75 (vaccuum tested with 13 - 15 hg), primary and secondary nozzles - #31
idle air bleeds - .073", high speed bleeds - .036"
idle feed restricters - .031"
the problem i am running into while driving is if i press the throttle half way (just before the secondaries open and the primaries are wide open) the car loses power and it jolts but i can give it more gas and it goes right past it. it also does the same thing during WOT only at 6200 rpm and up. i need to shift at 6800 - 7000 rpm, everything is set up to make power up to 8000 rpm. by jolting i mean it stops accelerating and makes a "zzzzzz" or humming sound. i assume that its leaning out but larger secondary jets have not helped.
also, when i am starting to move from a stop i have to rev it up kinda high or else it will stall out. but i fixed this problem by playing around with the air bleeds, i switched one of the idle bleeds with a high speed bleed and it drove beautifully. i switched it back because i dont think that is the proper way to fix the problem. plus, that did nothing for the jolting at high rpm.
so now i am at a loss and i need someone to tell me what to do. any suggestions?
302 bored .030 over
10:1 compression
RE: i need carb help, BAD!!!
no one has any clue??? i talked to quickfuel and they said to try smaller squirters. i am not sure how that will help up top but i guess ill try it. does this make sense to anyone? any other suggestions?
ORIGINAL: turboitall
My engine is not much different from yours. I just talked to Barry Grant last week and they advised me to run:
Front squirter-28
Rear- 31
Front jets -72
Rear- 80
Is the accelorator pump in spec? What accelorator pump cam are you using? Everyone I've talked to said to use the pink one.
ORIGINAL: Grimace5.0
Because the squirters you have are puting out too much volume.
Front squirter-28
Rear- 31
Front jets -72
Rear- 80
Front squirter-28
Rear- 31
Front jets -72
Rear- 80
after reading I still don't know what carb you have...
if I knew I can solve this for you....what cam is on the linkage?.
what acc. pumps?
is the air horn milled?
also the linkage for the other 2 barrel needs a lil adjustment to come in
what acc. pumps?
ORIGINAL: vfast
what acc. pumps?
what acc. pumps?
