my mods for 12's n/a and 11's on small shot
Old 11-27-2005, 12:17 AM
  #21
rsw007
rsw007's Avatar
Default RE: my mods for 12's n/a and 11's on small shot
ORIGINAL: ZachW04Stang
Nice setup, those are very impressive ets for a just bolt on car and built trans. Just think of what you could do with h/c/i added to that.
Does that belt you have run the water pump? What size is it? Did you switch to a manual rack or did you just plug up the power one? Also were you able to calibrate your speedometer for the 4.10's?
In the engine pick it looks like you don't have a crossmember. Whats up with that? Did you go with a tubular one?
yes runs water pump but sqeals on startup. dont remember the length. manual rack. speedo is still off. stock k-member.
vfast,
the n/a vid above was in july low 90's temp and high hum. da of 2600ft my 12.88 was in febuary 40's temp and low hum. and da of -2000 ft.
rsw007 is offline
Old 11-27-2005, 01:17 AM
  #22
fordguy17
fordguy17's Avatar
i have been to that dragstrip, but i never raced on it. i went to lowcountry dragway instead (1/8 mile track). are you familar with it?
anyways i ran a 9.1 at 77mph with a 2.1 60 ft time.
mods are as follows:
3.90 gear
2800-3000 rpm converter (don't know what brand, launched at idle)
shift kit
u/d pulleys
full exhaust
no smog
msd/crane ignition
rear control arms/front edelbrock spings
nitto 555r radial.
i now have a ported lower intake manifold, and will soon be getting 76mm mass air with inlet tube and 65mm tb.
at the time i had no experience with my car (just got it) but have since figured out how to launch it. i need to get back to the track and try again.
hell-maybe i should let you drive!
fordguy17 is offline
Old 11-27-2005, 11:02 AM
  #23
vfast
I ♥ Acer
vfast's Avatar
where da hell is that track..no timers to see time....dam hillibilly track
vfast is offline
Old 11-27-2005, 11:33 AM
  #24
rsw007
rsw007's Avatar
ORIGINAL: vfast
its a nice track hooks better than anywhere ive ever been. grudge nights they dont show times.
https://mustangforums.com/albumtn.as...z299897152.jpg
rsw007 is offline
Old 11-27-2005, 11:42 AM
  #25
rsw007
rsw007's Avatar
www.carolinadragway.com
rsw007 is offline
Old 11-27-2005, 11:48 AM
  #26
vfast
I ♥ Acer
vfast's Avatar
how far from mytrle beach?....I do like that atleast it's still open this late in the season....I might try the place when I come back down to m. beach
vfast is offline
Old 11-27-2005, 11:57 AM
  #27
rsw007
rsw007's Avatar
about 4 hours its near augusta,ga
rsw007 is offline
Old 11-09-2006, 07:19 PM
  #28
DSmith
DSmith's Avatar
What type of nitrous setup you running, wet or dry? Anything special about the kit, your getting some killer times
DSmith is offline
Old 11-10-2006, 07:37 PM
  #29
rsw007
rsw007's Avatar
its a compucar kit but swapped out nozzles and jets. jet size is 59n 40f
rsw007 is offline
Old 12-16-2006, 11:38 AM
  #30
rsw007
rsw007's Avatar
i want 10's now on ported stock lower and ported e7's and 125 shot
rsw007 is offline
Quick Reply: my mods for 12's n/a and 11's on small shot
