my mods for 12's n/a and 11's on small shot
Old 04-09-2007, 02:29 PM
  #41
w8less
w8less's Avatar
Default RE: my mods for 12's n/a and 11's on small shot
ORIGINAL: SN95Stang
wow nice man, why did u cut the springs tho?
IIRC he said for a nice look.
w8less is offline
Old 04-09-2007, 02:31 PM
  #42
SN95Stang
SN95Stang's Avatar
o ok....does the drag springs make the car ride higer in the front than the rear if they arent cut?
SN95Stang is offline
Old 04-09-2007, 03:39 PM
  #43
luckythirteen13
luckythirteen13's Avatar
very nice set up!
off the shelf converters = junk. of all the companies that makes sh*tty converters, you chose the worst (b&m). i wouldnt run a b&m in my car if you paid me to. i guarrenty that when you put the converter in, it will stall much lower then its rated at
luckythirteen13 is offline
Old 04-09-2007, 06:53 PM
  #44
rsw007
rsw007's Avatar
ORIGINAL: SN95Stang
yes, drag springs are taller and will ussually need cutting. but they work
rsw007 is offline
Old 11-20-2008, 03:50 PM
  #45
rsw007
rsw007's Avatar
UPDATED MODS and new times in sig.
engine
1. bbk cold air kit
2. 76mm mass air
3. 70mm throotle body
4. adjustable fuel regulator 42psi
5. underdrive pullies
6. electric fan and 130amp alt.
7. timming set at 14 degrees for the spray
8. bbk shorty headers "unequal"
9. upr x-pipe "offroad"
10. summit bullets with turn downs
11. Stock intake and cam
12. iron gt-40 heads
tranny
1. red eagle clutches and kolean steels
2. mechanical diode drum with 2" kevlar od band
3. a servo
4. pa manual valvebody
5. 3000 stall edge converter "lock-up"
6. pa hardend input shaft
suspension
1. 4.10 gears
2. moroso front drag springs with 2 coils cut out, monroe struts for 4cyl., upr c/c plates
3. steeda lower control arms, upr adj. uppers with spericals, lowering springs with 1/2 coil cut out.
4. sub frame conn. and driveshaft loop.
5. welded boxes
6. air bags in rear 5lbs driver 12lbs passenger side
weight removed
1. no sway bars, ac, ps, smog, dogbone, sound deadener, jack and spare, foglight bar
2. weld wheels with skinnys..
3. battery moved to the hatch
tires
1. on the spray 275/60 m/t drag radials 28 x 9
im sure i forgot something so feel free to ask.
rsw007 is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
daltron
04-28-2016 08:10 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
TimeLord101
10-01-2015 06:40 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: my mods for 12's n/a and 11's on small shot
