cam question...
Old 12-07-2005, 05:48 PM
90Mustangfan
I ♥ Acer
90Mustangfan's Avatar
Default cam question...
what makes a cam have the real lopey idle? the higher the lift nuber the loper the idle???...Im not sure but is the higher the lift on the cam, the more top end power its made for? what wrong with going with afr 165 heads and going with a big cam with like .600 lift ...and make sure the heads have dual spring package so they can withstand the cam..would this work..would this work?
90Mustangfan is offline
Old 12-07-2005, 06:10 PM
spudz
spudz's Avatar
Default RE: cam question...
duration and lobe separation makes it have a choppy idle. Lift is just how far the valves open.. Maybe someone else can answer the questions about the heads better then I can. but with a lift like that, you will run into valve contact with the pistons. NOT GOOD.. You can get aftermarket pistons to compensate for this somewhat.
spudz is offline
Old 12-07-2005, 06:13 PM
88BlueGT
88BlueGT's Avatar
You cant run anything over like .515' w a stock bottom end. I THINK>>>
88BlueGT is offline
Old 12-07-2005, 06:26 PM
OnyxCobra
OnyxCobra's Avatar
My buddy is running AFR 165s and an E303 w/ 1.72 rockers (= .535 lift) and he's ok. I think when u get around .550 lift is where you're gonna start getting problems with the heads.
OnyxCobra is offline
Old 12-07-2005, 08:38 PM
schwindty
schwindty's Avatar
^^^Thats about right, plus the head gasket is a factor as well.
schwindty is offline
schwindty
schwindty's Avatar
AS well the cc of the heads.
Old 12-07-2005, 09:01 PM
88BlueGT
88BlueGT's Avatar
Wow, thats a little bit off from what I said I actually was going to put a Lunati (.512') in my 5.0 and someone told me that I would JUST make it but they wouldnt recommend it. That was a long time ago but for some reason it just stuck with me. Sorry for the bad information
88BlueGT is offline
Old 12-07-2005, 11:49 PM
tinman
tinman's Avatar
Piston/valve clearance is the real issue about what you can run. It all depends on where the cam timing is set, advance/retarded/or 'straight-up'.
The 'lope' comes most from valve overlap event in the cycle...........
tinman is offline
Old 12-08-2005, 08:50 PM
vfast
I ♥ Acer
vfast's Avatar
overlap also the c/l of the cam has alot to the way it proforms
vfast is offline
Old 12-08-2005, 10:14 PM
tinman
tinman's Avatar
Ok, think of it this way, if you change the cam you are doing the same thing as putting a new program in your 'puter at home. Everything changes..........
tinman is offline
Quick Reply: cam question...
