Valve Covers clearing
YES ALWAYS USE THE THICK RUBBER GASKETS!Cork is junk.When i put my engine together i used the motorsport valve cover stud kit.Its nice to be able to put the gasket on and then the valve cover rather than try to line up the gasket bolt and hole and keep everything in place.</P>
Not to mention those rubber gaskets dont absorb the oil and eventually start to leak,and theyre reusable.</P>
I have the trick flow intake as well, and am using a 3/8 spacer... do you think I would clear the valve covers with just the 3/8? or myabe I don't even need that... can you let me know?</P>
Originally Posted by Milky
Ive got 1.7, are there a lot out there where the 1.7 wont clear? Can i take a dremel to the inside of the caovers to make them clear?
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
