problems after timing chain ch
After I changed my timing chain my oil press sensor goes down to zero and car warms up quicker in the morning and i have noticed a little loss of power. Does anyone have any ideas what may have done wrong or is there something I could check to make sure i did it right. <edited><editID>olb55</editID><editDate>37996.726875</editDate></edited>
normal temp about 180, it just gets up there quicker than it did before. I notice loss of power at high rpm range 4 1/2 to 6<edited><editID>olb55</editID><editDate>37998.6328356481</editDate></edited>
I'm not sure what kind they were but i have everything off again and i have the bottom gear at 12:00 but the top gear won't go in so i turned the bottom one counterclockwisemaybe 1/8 of an inchand it lined up with top gear notchit should be in the correct placeboth marks are like this :
my book told me to turn the crank until the two marks weretogether and I did and I brought the 1 pistonup. If i'm off a too the againg will using a timing light let me know if it is off. thanks for tring to help I just don't no what to do it seems like i followed the directions in the chiltons and it might be still messed up
did you put on just a chain orsprockets also?... if you put on new sprockets, is the new crank one adjustable....if so make sure the keyway is in the 0 degree spot...usually the have 3 slots, -4*,0*,+4* when you sy you lost mid-top end that would suggest that you are not in the 0* slot...hope this helps</P><edited><editID>Black Horse</editID><editDate>37998.7337847222</editDate></edited>
