what size wheels and tires
I have a 91 notch and i want to buy a set of draglites and bfg dr's. I was just wondering what size is recomended(wheels and tires) without having to use a hammer to make room and what size wheel spacer would i need? thanks<edited><editID>dohc_cobra</editID><editDate>37997.1721759259</editDate></edited>
YOU NEVER RUN STICKIES AND SPACERS depends on the size of wheel your running. when picking out wheels you need to look into offset, diameter, strenght,weight, clearence
hell i can say you can put 20s on it but what will that do for you. you need to tell us your wheel size, your suspension and so on.
if just runing pony wheels you can fit 245/50/16s DRs. but remember no two tire brands are the same size. i run 255/50/16 DRs on my 88 hatch but i also have a different offset on the wheels. my buddy with his 92 hatch with ponys rub with 245/50/16 DRs. off the pipes and quad shock
