Cam and heads?
RE: Cam and heads?
Here is where you can see how much they flow: RHS SBF Heads
Here is a table of other popular heads and how much they flow:
RE: Cam and heads?
You would be looking at a CompCams 35-522-8 or 35-518-8. I can get you both of these, and they also come in a kit. Have you thought about the RHS heads? Did you compare them to the AFRs? Any questions?
RE: Cam and heads?
Ok I need help , I'm from fresno calil and this is what i have
Roller block alumiun crank.
R&Rforged pistons 5.400 rods
RPM proformer AIR GAP intake
long tubs hooker competions
RHS heads 200cc cnc ported and polish flow 265 cc @ 700 Rpm
grindle 7qt oil pan
MSD everything
electric fan
alumum radiator
C4 tranny 3800 stall
4.10 gears
tractions bars
upper and lower adju control arms
Hard lunch kit.
sub frame connectors
debating on rather i should go electric water pump or not. Hers's my questions I need a good cam. I heard SBF don't need alote of durations.
grindle 7qt oil pan
MSD everything
electric fan
alumum radiator
4.10 gears
tractions bars
Hard lunch kit.
RE: Cam and heads?
AFR heads kill RHS. They actually flow what they are advertised for and have a better shape and Full CNC.
I know this is 2 years old, but why would anyone compare a 210cc head to a 185cc head when they have the same runner length?
Of course the 210cc is going to "flow more". Compare it to an AFR 205 next time
RE: Cam and heads?
Promustangperformance I checked out your website and your prices are very competitive.
If you are going with AFR 165s I would call Comp, Crane, or Lunati and see what they tell you, then call Promustangperformance and price it through him.
RE: Cam and heads?
If you are buying AFR heads go with Ed Curtis @ www.flowtechinduction.com
He actually knows what he is doing.
Onyx - That was funny
