smog pump yes or no
RE: smog pump yes or no
you cant just bypass it with a shorter belt. you have to buy the smog pump delete kit. i got a smog pump delete kit on my car and i love it. i picked up about 5 hp from it . i would take it off if you dont have emissions to pass.
yeah you can bypass it with a shorter belt if you want but its a lot better to take it off all the way. i have mine bypassed right now but ive only driven it about 2 tanks of gas since i did it.
ORIGINAL: ekthrilla
Yes you can bypass it dont spend extra money on a delete kit just use a shorter belt and remove the pump. cap of the hose at the h-pipe and the the pipe going to the heads, but if your still running cats they will clog up over time.
i have tried to by pass the pump but i couldnt ever figure out a way to run the belt . you cant just run the belt the same way because when you dont go around the smog pump there isnt any tention on the tentioner pulley. maybe someone can send a link of a picture of this because i tried several different ways and i couldnt find a way to do it at all. maybe fox's belt is ran differently. remember that i have a SN95.
