QUARTER MILE TIMES
Old 04-30-2003, 05:26 AM
JUICE
JUICE's Avatar
Default QUARTER MILE TIMES
DOES ANYONE KNOW WHAT STOCK 92 AUTOMATIC GT RUN FROM FACTORY?
JUICE is offline
Old 05-01-2003, 08:50 PM
SunnyJim302
SunnyJim302's Avatar
I have a suggestion for you...if you go to download.com.com (yes there's two .coms) download "Virtual Engine Calculater Demo" You just input certain specs on your car, and hit calculate and it tells you. you can calculate rwhp, torque, ci, bore, top mph in a certain rpm range - it does a lot. try it out, it'll give you a good ballpark figure of what your car can do.
SunnyJim302 is offline
Old 05-01-2003, 10:39 PM
makarovboy
makarovboy's Avatar
Bone stock? Probably mid to low 14's, depending on trans, gears, etc.
makarovboy is offline
Old 06-04-2003, 01:16 AM
mustang50
mustang50's Avatar
since it is automatic i would say mid to high 14's depending on your launch.
mustang50 is offline
Old 06-04-2003, 09:08 PM
Snake
Snake's Avatar
I agree
Snake is offline
Old 06-05-2003, 06:50 AM
yellow94gt
yellow94gt's Avatar
You guys think it will run that fast? I have a friend with a modified (not heavily) (flows, ram air, and pullies) on a 92 5 spd gt, and he runs low 15's. I dont know, you guys would tell it better I just got a 94, my first mustang. He runs on street tires and most likely spins a bit.
yellow94gt is offline
Old 06-05-2003, 08:06 AM
goldbomb79
goldbomb79's Avatar
I know my 89 mustang gt with a 5 speed was suppose to run 15.2's in the 1/4 mile stock. i would think the 92 should be somewhere around there also
goldbomb79 is offline
Old 06-05-2003, 07:36 PM
95_GT_Stang
95_GT_Stang's Avatar
Go to WWW.car-stats.com they have 1/4 times, 0-60, etc. for every model year you can immagine.
95_GT_Stang is offline
Old 06-05-2003, 07:41 PM
converted
converted's Avatar
Don't forget the driver has a lot to do with it too. I have watched a guy (my neighbor) with a '94 that had a complete edelbrock upper setup, headers, 3.73's, 150 hp shot, and a few other parts only run 15.6's. He just couldn't figure out the launch and had a problem with breaking the tires free with 1-2 and 2-3 shifts (spun tires).
The same guy could only pull a mid 12 out of his 2000 CBR 929RR. A friend of his pulled into the 11's.<edited><editID>converted</editID><editDate>37777.7380208333</editDate></edited>
converted is offline
Old 06-05-2003, 07:50 PM
Sean
Sean's Avatar
You said it converted, driver abitlity.
Sean is offline
djbigskrilla
09-20-2022 01:04 AM
Roger Mabry
06-15-2016 08:27 AM
Tyoung68
08-25-2015 04:31 AM
kdryan
The Racers Bench
08-22-2015 02:14 PM
Displ8cement
Texas Regional Chapter
08-13-2015 12:37 PM
Quick Reply: QUARTER MILE TIMES
