Bad Vibration
Old 01-05-2006, 07:23 PM
stanglx2002
stanglx2002's Avatar
Default Bad Vibration
My friends car has a real bad vibration above 2500 rpms and gets even worse the higher the rpms go. I checked the balancer and its fine the only other thing i can think of is U-joints. Does this sound right and also can you just put grease fittings in the joints or should you replace the joints with new
stanglx2002 is offline
Old 01-05-2006, 07:54 PM
gjmack3
gjmack3's Avatar
Default RE: Bad Vibration
Replace the joints with ones that have zerks in them already. you might also need to get the driveshaft re-balanced if the vibration is still there. What gear ratio does he have?[8D]
gjmack3 is offline
Old 01-05-2006, 08:13 PM
angcobra
angcobra's Avatar
Is the vibration only during driving or does it do it in Neutral.
If it is on the road does it do it in all gears at 2500 or just some gears? Does it continue to vibrate if you shift to neutral running down the road?
angcobra is offline
Old 01-05-2006, 08:20 PM
5.0 MPG
5.0 MPG's Avatar
That sounds like a nail in his tire or if he hit a curb or something like that hard it may have bruised his tire either way creating a imballance that vibrates at about 60 to 70 MPH. Try to locate the side and inspect the tire.
5.0 MPG is offline
Old 01-06-2006, 08:35 AM
stanglx2002
just when he's driving he does a small vibration when out of gear too but its real bad when driving
Old 01-06-2006, 03:42 PM
81ponycar
81ponycar's Avatar
I would say that it is the joints also, so replace those then see if it still vibrates.
81ponycar is offline
Old 01-06-2006, 03:45 PM
85stangman
85stangman's Avatar
i say to re place the joints if it still has bad vibration then go futher
85stangman is offline
Old 01-06-2006, 03:49 PM
Tims 88GT
Tims 88GT's Avatar
what do the motor mounts look like?
Tims 88GT is offline
Old 01-06-2006, 03:54 PM
stanglx2002
there fine cracked but fine i checked that too he is putting in new joints today so we will see what happens
Old 01-06-2006, 10:17 PM
stanglx2002
th U joints werent the problem
Quick Reply: Bad Vibration
