Dipstick gone bad?
Dipstick gone bad?
After my oil change today (I got all of the oil out of the crankcase BTW), I put 4.5 quarts of oil in and some CER lifter lube/cleaner (about .25 of a quart) in there. My dip stick is reading about 1.5 quarts over now and I am sure that I am not over full, could the dipstick be pushed in too far, idk, anyone ever had this problem? This is really hard to explain lol.
RE: Dipstick gone bad?
ORIGINAL: ColdAudio
dont mean to hijack, but theres another plug besides the pan?
ORIGINAL: fordguy17
did you pull both the drain plugs?
i've made that mistake before too...
just making sure you didn't over look the obvious.
One toward the back and another in the very front of the pan.
EDIT: can't spell
I changed my oil today and I only put 4 quarts in. I did pull both plugs also. The dip stick said I was right at the top. im going ot check it again tomorrow after I was the car.
ORIGINAL: Grimace5.0
There are two plugs in the pan.
EDIT: can't spell
ORIGINAL: ColdAudio
ORIGINAL: fordguy17
EDIT: can't spell
Yup there's a second plug, I had neglected it my past 4 oil changes but this time I used it and drained another .5 of a quart out. So should I get a new dipstick? It's almost as if the dipstick pushes too far down into the tube and is reading about a quart over where it should be, like I said I only added 4.5 quarts and the lifter cleaner was only about .25 of a quart. Maybe I'll get a new dipstick and see if that helps any.
