cam size???????
cam size???????
i have a 90 lx and i am pulling my motor out to change the oil pan gasket and to clean up the engine compartment and while i got the motor out im going to through a cam in it..since it has stock heads w/o p/p im goin to go w/ a double grind cam..
i want to know wut the best cam to get would be .....trick flow, lunati, comp cam....and will it slide right in w/o valve and piston clearance issues..??
give your recemendations plz....
thanks
thanks
RE: cam size???????
it would be a waste of money
if you put in new heads, and upgraded the intake, along with maybe pistons then you'd see a bigger gain than with the stock motor.
actually the stock cam isn't bad from what the motor is... it's the heads and intake that restrict it the most
RE: cam size???????
Unless your just going for the sound a performance cam makes, i would put the money elsewhere.
I dont know what mods are done to your car thus far but if you cant put stock power to the ground then i would put the money into the suspension.
If you are just going for sound then i would recommend the trickflow stage 1 with 1.6 rockers.
Rye
Rye
RE: cam size???????
You could try calling Crane, Comp, Lunati, Isky, TF, Crower, or any other major cam manufacturer. They have tech lines for a reason. Give them your specs & they'll recommend a cam with better accuracy than the internet (no offense to those for with real cam knowledge). You'd be best off with supporting work first (heads, intake, exhaust), since there isn't a whole lot the stock package can do regardless of the cam.
RE: cam size???????
ORIGINAL: 92BOOSTED
Rye
Rye
RE: cam size???????
I disagree with all of u guys! my last 5.0 was an '87 LX and I had a damn good setup. I did have a cam with stock heads. the comp cam xtreame energy with 224 duration. the only thing i did to the actual motor to help it was I put #24 injectors in it. everything ran fine. it had a motor rebuild only about 15k ago when i did it though, so everything was fresh. u dont need heads and manifold and all of that bull. just know how to tune it right and it shouldnt have any problems.
