T-5 tranny swap
Old 01-12-2006, 12:05 AM
1stStang
1stStang's Avatar
Default T-5 tranny swap
Hello again, has anybody out there done a complete Auto to Manual transmission swap? If so how labor intensive is it, and what all is required for the change out. I know that you need pedals, bellhousing, tranny, clutch, linkages, wiring harness, computer, flywheel. Is there anything else required? And does anybody know where a complete kit can be purchased from (salvage yard)?
1stStang is offline
Old 01-12-2006, 12:40 AM
ballzoutstang875.0
ballzoutstang875.0's Avatar
Default RE: T-5 tranny swap
my car was an auto when i bought it, but i made a deal with the guy for him to put the 5 speed in because he does trans. work for a living. im pretty sure u listed about everything, but make sure the sincros. inside the trans. arent bad. i made that mistake when i got this car and the guy had to pull it out again and rebuild it. theres really nothing to putting in a manual tranny.
oh, cable obviously, and the clutch quadrant under the pedals.
ballzoutstang875.0 is offline
Old 01-12-2006, 12:44 AM
90lxrider
90lxrider's Avatar
yea i just did a swap in my 90 ...u dont need to touch the computer if u have an AOD but if u have an AOD-E , E standing for electronic then u need to mess w/ it ...but if u have an 87 u shouldnt have to worry bout it
go to prestigemustang.com and email Todd
^ all they do is deal with mustangs, the president Todd actually owned my car and i bought it from him hope it helps u out a lil bit
90lxrider is offline
Old 01-12-2006, 03:18 AM
1stStang
1stStang's Avatar
Thanks for the info and link. I would be swapping out my AODE in my 95 GT. I absolutely hate the auto tranny that is in my car. I have done auto to manual swaps in GM cars before but never in anything Ford or new. All my swaps were in late 60's/early 70's muscle cars and they were easy. If anybody has any idea where I can get all the components for the swap please let me know. Thanks!
1stStang is offline
Old 01-12-2006, 09:53 AM
stanglx2002
stanglx2002's Avatar
this should help you out
http://www.allfordmustangs.com/Detailed/25.shtml
stanglx2002 is offline
Old 01-13-2006, 06:26 AM
Nobityeaho
Nobityeaho's Avatar
My 91 gt convertible was auto when i got it, i had my dad do a t5 swap at roush. It took a couple days, about 7 hours each. We didnt have to change the wiring harness or the computer, but we did have to do a little wiring work on the plugs that go into the trans. I hear it is a good idea to replace the stock aluminum bearing retainer that tends to wear out, with a steel replacement from ebay or wherever you can find one. we didnt replace mine and i get a few noises i think would go away if i replace that. But its totally worth it, the difference between auto and manual is like night and day.
Nobityeaho is offline
Old 01-13-2006, 07:05 AM
madmark69
madmark69's Avatar
I did this swap on my 95 GT --the AODE was going out so I swapped to a Tremec 3550, instead of a T5, but the process is the same. I used the flywheel from the 88 and got the rest of the parts I needed-- wiring harness and pedal assembly -- from a junk yard. Had to buy a manual tranny specific computer from a Ford dealer. Also had to trim sheetmetal in the transmission tunnel to get more clearance for the shifter. The swap only took me about one day to do.
madmark69 is offline
Old 01-13-2006, 07:06 AM
madmark69
madmark69's Avatar
Old 01-13-2006, 11:41 AM
nitrous_bob
nitrous_bob's Avatar
check out this link...very thorough walkthrough, and a printable checklist.
http://www.wcfords.com/articles/tech/t5swap/t5swap.html
nitrous_bob is offline
Old 01-13-2006, 03:07 PM
Tims 88GT
Tims 88GT's Avatar
i did the swap in my 92gt, its not hard, the hardest part is puttin the pedals in but thats still not that hard. it a lot nicer havin my t-5 back
Tims 88GT is offline
Quick Reply: T-5 tranny swap
