spedo gear
spedo gear
don't know what transmission you have here is a chart
Manual Transmissions with 7 Tooth Drive Gear
* 1983-1989 T-5 OEM
* Pre 1993 T-5 Aftermarket
* 1996-1998 Cobra T-45 OEM
* All Tremec Transmissions
2.73 Gear Ratio / Maroon 16 Speedo Gear
3.08 Gear Ratio / Yellow 18 Speedo Gear
3.27 Gear Ratio / Pink 19 Speedo Gear
3.55 Gear Ratio / Black 20 Speedo Gear
3.73 Gear Ratio / Red 21 Speedo Gear
4.10 Gear Ratio / White 23 Speedo Gear
Manual Transmissions with 8 Tooth Drive Gear
* 1990-1995 T-5 OEM
* 1996-1998 T-45 OEM Except Cobra
2.73 Gear Ratio / Yellow 18 Speedo Gear
3.08 Gear Ratio / Black 20 Speedo Gear
3.27 Gear Ratio / Red 21 Speedo Gear
3.55 Gear Ratio / White 23 Speedo Gear
3.73 Gear Ratio / White 23 Speedo Gear
Automatic Transmissions with 7 Tooth Drive Gear
* 1983-1989 Automatic Transmissions
2.73 Gear Ratio / Blue 16 Speedo Gear
3.08 Gear Ratio / Gray 18 Speedo Gear
3.27 Gear Ratio / Tan 19 Speedo Gear
3.55 Gear Ratio / Orange 20 Speedo Gear
3.73 Gear Ratio / Purple 21 Speedo Gear
Automatic Transmissions with 8 Tooth Drive Gear
* 1990-1998 Automatic Transmissions
2.73 Gear Ratio / Gray 18 Speedo
3.08 Gear Ratio / Orange 20 Speedo Gear
3.27 Gear Ratio / Purple 21 Speedo Gear
* 1983-1989 T-5 OEM
* 1990-1995 T-5 OEM
spedo gear
Originally Posted by vfast
</P>
damn. i think www.50resto.comhas em</P>
spedo gear
It sucked getting the cable to go through the firewall (you will probably want two people for that). And in my case I have larger aftermarket exhaust so it was a beeotch getting the speed sensor (what the cable hooks into)to fit in the trans just right, because the exhaust gets into the way. <---lots of cursing. You will also need one of those hex keys I beleive to get the gage cluster out. Note the angle of the windsheld in relation to the top of the gage cluster. You will need a short one or one that has a 90degree turn in it to get the screws loose. But other than that it was pretty easy I'm a lousy mechanic. oh yeah have fun getting your hazard and headlight swithes to come out. I think you can slide a flat head down the side of them to get them to unclip. Don't crack the plastic things they snap into or they will never sit fixed in the cluster. And be careful unplugging the wiring harnesses from the back of the cluster dont yank it out.
spedo gear
I figured out that it was only 5 or 6 miles off is that enough for a new gear or is there something wrong with my gage cluster.Oh yeah what is the right tire size for the stock 5star wheels. found out that it is 225-55-16 I got 205-55-16 on the car. the "205" thats the tred depth right? that wouldnt make my speedo off would it?<edited><editID>sevorg</editID><editDate>38008.5603356482</editDate></edited>
