power @5500 rpm
Old 01-27-2004, 03:10 PM
pro5.0stang
pro5.0stang's Avatar
Default power @5500 rpm
ive been shifting at 5500. if its 225hp@4000 rpm. should i shift at4000? could that be hurting my quarter mile times?
pro5.0stang is offline
Old 01-27-2004, 03:27 PM
tripsevn7
Moderating with Angels
tripsevn7's Avatar
NO, YOU WANT TO BE OVER PEAK SO WHEN YOU SHIFT AND LOSE RPMS, YOU ARE STILL AT THE TOP OF YOUR CURVE. KEEP SHIFTIN CLOSE TO 6K SO WHEN YOU FALL AND THE DRIVETRAIN IS ENGAGED, YOUR HOLDIN38-4200.. MY OPINION
tripsevn7 is offline
Old 01-27-2004, 04:49 PM
Quik
Quik's Avatar
you power lose power after 4800rpms. shifting to high is going to hurt your performance on a stock motor. cause you could be making more power in a different gear
Quik is offline
Old 01-27-2004, 05:14 PM
mkspeed26
mkspeed26's Avatar
</P>
but your rpms carry over to the next gear and if you shift too early then you have no power in the next gear. so you have to find the right tradeoff. </P>
mkspeed26 is offline
Old 01-27-2004, 05:22 PM
Quik
Quik's Avatar
</p>
but your rpms carry over to the next gear and if you shift too early then you have no power in the next gear. so you have to find the right tradeoff. </p>
one a good stick driver doesnt lose to many rpms. if you shift at 5200 when you hit second gear youll bearound
4000 which is around the power band.shifting higher you lose to much time.
Quik is offline
Old 01-27-2004, 05:55 PM
vfast
I ♥ Acer
vfast's Avatar
on that stock engine 52-5300 at the most...sifting at 6k will result in a slow time and a hurt engine or valve float... be more concerned with a good launch and fast shifts it's all about being consistent
vfast is offline
JDWalton
09-24-2015 08:47 PM
uberstang1
09-20-2015 06:42 PM
2015Ecoboost
09-17-2015 01:48 PM
Daddys Girls GTs
09-14-2015 08:46 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: power @5500 rpm
