30 lbs. injectors
Old 01-28-2004, 05:41 PM
horatio102
horatio102's Avatar
Default 30 lbs. injectors
hypothetically speaking:
with 100cfm of air going through the MAF it reads let's say 2 volts when calibrated for 30lb injectors, causing the eec to call for X amount of fuel. If using a maf calibrated for 24 lb injectors, the voltage would be increased due to the longer pulse required to squirt the same amount of fuel with 24lb injectors. So using 30 lb injectors with a MAF calibrated for 24 lb injectors will result in higher voltage than required, longer pulses, and more fuel being dumped in. It's not that the injectors would go full cycle, just that they're 25% larger injectors than the eec/maf expects.
horatio102 is offline
Old 01-28-2004, 06:05 PM
FUNNELWEBSPYDER
FUNNELWEBSPYDER's Avatar
reading what i typed in my initial post, i must apologize for the confusion i have created.first, all the parts listed above are parts WAITING to go onto my car. its all in boxs in my basement. along with a whole bunch of other stuff i didnt list. second, i dont have 24lbs. injectors. my car still has the 19lbs. squirters. i just didnt want to install all this stuff at once just to take some of it back out (like the injectors). any-hoo, i will get some 24lbs injectors. and go at it. my vavles are 1.90. and i'll still sell the 30's. its the only way i'll be able to pay for the 24's. my wife wont let me get any more stuff<img border="0" src=smileys/smiley6.gif border="0">( so i'll have to be sneaky)
FUNNELWEBSPYDER is offline
Old 01-28-2004, 06:22 PM
Quik
Quik's Avatar
Originally Posted by mkspeed26
stick with the 24s, and try to get them in spinners if you have the cash (just kidding, making a ricer remark)</p>
your really an idiot quit making those f***ing comments. one spinners are usually found on a Balla's ride not a ricer. it takes some serious cash to pick up a set. grow the f*** up and quit hijacking threads. if you dont know what your talking about quit postwhoring....
Quik is offline
Old 01-28-2004, 09:51 PM
mkspeed26
mkspeed26's Avatar
STFU!!! if you got your head out of your *** you might find some if these things funny.
mkspeed26 is offline
Old 01-28-2004, 10:56 PM
makarovboy
makarovboy's Avatar
If I were you, I'd go with 36's. What are you going to do, change to a larger injector each time you mod your engine?
Think about it. When you start the engine, the computer looks at throttle angle and water temp. Then it refers to the program already there, which is for 19's. Why not just go to the larger injectors on a lightly modified car? Then as you add more hp, you don't have to screw around with going to larger injectors. All this "too big" stuff is a myth unless you're considering monster injectors, and 30's are not even close. And even if you were considering mods for really big injectors, there are plenty of chip burners out there that have no problem at all making them work.
makarovboy is offline
Old 01-28-2004, 11:00 PM
n2o44
n2o44's Avatar
anyways , i recently put a combo with gt40x ported, trickflow stage1 cam long tubes,trickflow intake..... blah blah , it had 30lbs , and a 70mm tb and 80mm mass, if you know what you donning with a tunner or some one does there no prob , i had it idle very well , part thr was good and it hauled ***, period <edited><editID>n2o44</editID><editDate>38014.8771643518</editDate></edited>
n2o44 is offline
Old 01-29-2004, 01:46 AM
n2o44
n2o44's Avatar
agreed , monster injector are above 42 imo, people still get those and bigger to have no prob starting and idleing
n2o44 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: 30 lbs. injectors
